Create user
- Overview of the Create user Process
- How do I create new user details?
- How do I add primary account for a user?
- How do I add additional account for a user?
- How do I manage user customers?
- How do I manage user contracts?
- How do I assign a service to the user?
- How do I change application roles of the user?
The administration application provides facilities for creating a new user profile. The Create user screen is used to create a new internal or external user and assign the user a primary account, additional accounts, roles and services.
When you log in to the application you must have administrator rights. This link is available only to helpdesk admins.
The create user process involves the following five steps:
- Create user details
- Add primary account
- Add additional accounts
- Edit user application roles
- Assign user service
Of these five steps only the first two are mandatory and it involves providing basic user information and assigning primary account to the user.
Create user details
The Create user screen enables you to create a new internal or external user and assign the user a primary account, additional accounts, roles and services. The login name has to be unique in the BT admin application. LDAP lookup based user creation is also supported on the Create user screen. All BT users are referred to as internal users and are present in the BT LDAP directory.
Follow the steps detailed below to create a new user profile.
- Log on to the administration application with administrative rights. This functionality is available to helpdesk admin, DAM, CAM and eCAM.
- Click the Create user link from the left pane of the homepage. The Create user screen appears.
- Type login name for the user in the Login name field. This field accepts alphanumeric characters along with @ and underscore. If you are an internal BT user enter the EIN (Employee Identification Number) in the Login name field and click the lookup button. If your details are available in the LDAP, the details are populated in appropriate fields. The lookup facility is not available to eCAM admin.
- Select the title for user from Title drop-down list box.
- Type the first name of the user in First name field.
- Type the last name of the user in Last name field.
- Type the email address of the user in Email field. LDAP lookup can be done based on email id as well. If the user is present in the LDAP, the user's details are populated in appropriate fields. The lookup facility is not available to eCAM admin.
- Select the user type from the User type drop-down list box. Select GBC for external users and CAD for internal users. This option is not available to eCAM admin.
- Type the date on which the user account will expire in the Expiry date field. It should be greater than the created date. Alternatively, click the calendar icon and select a date.
- Select the status of the user from the Status code drop-down list box.
- Type the business phone number of the user in the Phone field.
- Type the first three lines of the address in the Address line fields.
- Type the name of the city where the user's business is located.
- Select a country from the drop-down list box where the user's business is located. Click the go button to fetch respective states.
- Select a state where the user's business is located.
- Type the post code/zip code of the place where the user's business is located.
- Type the user's business facsimile phone number in the Fax field.
- Type the user's business pager number in the Pager field.
- Type the user's mobile number in the Mobile field.
- Type the alternate phone number of the user in the Alternate phone field.
- Select a language from the Language drop-down list box. The language selected here is used to set the locale when the user logs into the portal. All email communication with the user would be in the selected language.
- Select a relevant user's time zone from the Time zone drop-down list box.
- Click next to go to the next screen.
- Click reset if you want to reset the fields to their actual state. You can re-enter all the information once again.
- Click cancel if you want to cancel the create user process.
The following is a screen shot of the Create user screen.
Add primary account
The Add primary account screen is used to assign primary account and role to the user. This is a mandatory step in the create user process. CAM, eCAM and company users can be assigned only a company as their primary account. DAM should only be assigned a distributor as his primary account.
Follow the steps detailed below to add a primary account to the user.
- Log on to the administration application with the helpdesk admin rights.
- Click the Create user link from the left pane of the home page. The Create user screen appears.
- Specify the user details and click next. The Add primary account screen appears.
- Select distributor from the list of distributors existing in the system. The selected distributor name appears in the Distributor name drop-down list box.
- Select company from the list of companies that are displayed. This list gets populated based on the selected distributor. The selected company name appears in the Company name drop-down list box.
- Select a user role from the User role drop-down list box. If the user type is selected as GBC on the previous screen, helpdesk admin and CAM roles will not be available in this drop-down list box. Help desk admin and CAM roles are available only for internal users, that is iCAD users. If user type is selected as CAD on the previous screen, eCAM role will not be available in this drop-down list box.
Note: Click add to open the Add additional accounts screen. You can add a secondary account for the user in this screen. The add button would appear in two cases:
- If the user is an internal user.
- Help desk creates an external user who is not a delegated admin.
Additional accounts cannot be assigned to delegated admin.
The following is a screen shot of the Add user primary account screen.
The Add additional accounts screen is used to add an additional account to the user. CAM, eCAM and company users can be assigned only a company.
Follow the steps detailed below to add an additional account to the user.
- Specify the primary account details and click add. The Add additional accounts screen
appears. The add button would appear in two cases:
- Select company from the list of companies that are displayed. This list gets populated based on the selected distributor. The selected company name appears in the Company name drop-down list box. If the newly selected company is already a user account then the message "User account already exists for the Company." is displayed.
- Click add to add an additional account.
The following is a screen shot of the Add user additional accounts screen.
Manage User Customers
The Manage User Customers screen is used to associate the user to customers which are linked to the company and the distributor selected in the Add user primary account screen.
Follow the steps detailed below to assign customers to the user.
- Click next to go to the next screen. The Manage user customers screen displays the username and user ID of the user being created.
- Select a company name from the Company section drop-down list. A list of customers that are available to be associated to the user and a list of customers associated to the user are displayed. Alternatively, enter the name of the customer in the Search for a customer field and click
to search for customers.
Customers matching the search criteria are listed in the Available customers list box. - Transfer the customers from one list to another using << and >> buttons.
- Click NEXT to assign the available customers and mapped customers to the user. If the customers are successfully assigned to the user, the Manage user contracts screen appears.
The following is a screen shot of the Manage user customers screen.
Manage User Contracts
The Manage User Contracts screen is used to associate the user to contracts which are linked to the customers selected in the Manage user customers screen.
- Select a company name from the Company section drop-down list. A list of customers that are available to be associated to the user and a list of customers associated to the user are displayed in two sections. Alternatively, enter the name of the customer in the Search for a customer field and click
- Click SUBMIT to assign the available customers and mapped customers to the user. If the customers are successfully assigned to the user, the Manage user contracts screen appears. The Manage user contracts screen displays the username and user ID of the user being created.
- Select a customer from the Customer drop-down list linked to the selected company. A list of contracts that are available to be associated to the user and a list of contracts associated to the user are displayed in two sections. Alternatively, enter the name of the contract in the Search for a contract field and click
to search for contracts.
Contracts matching the search criteria are listed in the Available contracts list box. - Transfer the contracts from one list to another using << and >> buttons.
- Click NEXT to assign the available contracts and mapped contracts to the user.
The following is a screen shot of the Manage user contracts screen.
Assign service to user
The Assign service to user screen is used to assign a service to the user. All portlets/services which do not require any authentication or holds authentications at application or account level are assigned to user by default. All user level authentication services must be explicitly assigned by providing user level credentials.
Follow the steps detailed below to search for a service and assign user service.
- Click the link from the left pane of the home page. The Create user screen appears.
- Select the user role from the drop-down list box.
- Specify the primary account details and click next. Alternatively, if an additional account is added, then click next.
- Select user application roles in the Change role screen and click next. The Assign user services screen appears.
- In the Assign user services screen, select the applications and services you want to assign to this user and move them to right list box. The services or applications which are assigned by default can also be deassigned by moving them to the Available applications/services list box. Click next. The Add SSO details screen appears if any services which require user level authentication are assigned to the user.
- Type user ID and password for the respective user level services in the Add SSO details screen and click next.
The following is a screen shot of the Assign service to user screen.
The following is a screen shot of the Add SSO details screen. If credentials are not provided the service would be pending for the user.
Assign application role
When an account is added to the user, by default, the user gets access to all applications and account level services which that account has. The Change role screen is used to amend the user’s application roles.
Follow the steps detailed below to change the application role of the user.
- Select company from the Company drop-down list box and click the go button. The applications to which the user has access to are displayed. All the roles which were defaulted for the company will be assigned by default to the user.
- Select the check boxes to select the roles. Clear the check boxes to deselect the roles. All checked roles will be assigned to the user.
The following is a screen shot of the Edit user application roles screen.
