Search and View Customer
  • How can I search customer
  • How can I view customer
    You can search the customers, for the logged in account ID, that you are associated to .
    Follow the steps detailed below to search the customers:
    1. Click Administration tab on the secondary navigation menu bar on the GS Portal home page. The administration login screen is displayed.
    2. Log on to the administration application.
    3. Click Customer / Contract link on the left pane of the page. The Search Customer screen is displayed.
    4. Select Customer from the Search For drop-down list.
    5. (Optional) Type the name of the customer you want to search.
    6. (Optional) Click on Advanced for advance search.
    7. (Optional) Select Customer ID or Customer name from the Search By drop-down list.
    8. (Optional) Select the name of the company, to which the customer is associated, from the Company drop-down list
    9. (Optional) Check the Remember My Options check-box if you want your search criteria to be remembered.
    10. Click Submit to submit your search criteria and perform a search based on the criteria. If no criteria are specified all the customers are listed in the search result screen. The Customer name, Customer ID, Account Reference and Company name are displayed in the screen.
    11. Click on the name of the customer to view the details.
    The following is a screen shot of the Search Customer screen:
    Return to top
    How can I view customers
    You can view the customers, for the logged in account ID, that you are associated to .
    Follow the steps detailed below to view the customers:
    11. Click on the name of the customer for which you want to view the details. The Maintain Customers screen is displayed. The Customer Name, Company, Customer ID, Creation Date, Status, Account Reference, list of contracts associated to it and the User Details are displayed.
    12. Click on the contract name to view it's details.
    13. Click on the relevent quick link present under the User Details section.
    The following is a screen shot of the View Customer screen:
    Return to top
